Hi, well basically I cannot change much now regarding the measure widget, style of the line, cannot change the labels (are you sure they are html elements??). As you've mentioned, it's all webgl. Btw I cannot control the weidget the way I wish... how do I activate drawing (via view.activetool.activate(), but it's not documented. I'd like to be able to connect to some public events, not just to 'watch' the properties in order to guess if that's the correct value for the event I'd like, example given would be onMeasureDone or similar so I can display my own UI.
The lack of all these will force me to look into webgl and to use the external renderers to do what I need on my own terms.
Don't take it wrong, but the lone public method ''cancelMeasurement' or whatever and no public subscription points is just not enough for the widget that actually does so much!
