Greetings,
I've written a react application that requires a SceneView. About every 20th refresh the application maxes out my memory and crashes. I can write the whole application with a MapView instead and everything is fine. I also get an error each time I load the SceneView:
[esri.core.Accessor] Accessor#set Assigning an instance of 'esri.views.ui.DefaultUI' which is not a subclass of 'esri.views.ui.3d.DefaultUI3D'
Does this error have anythign to do with the memory being maxed out every so often?
The code I'm working with is :
import React, { Component} from 'react'
import EsriLoaderReact from 'esri-loader-react'
import MapOverlayPanel from '../../molecules/MapOverlayPanel/MapOverlayPanel'
import './ESRIScene.css'
class ESRIScene extends Component {
constructor(props){
super(props)
this.state = {
SceneView: null
, searchResultGL:null
this.loadMap = this.loadMap.bind(this);
loadMap = ({loadedModules: [WebScene, SceneView, Locate, GraphicsLayer, DefaultUI], containerNode}) => {
const self = this
let map = new WebScene({
portalItem: { // autocasts as new PortalItem()
new SceneView({
container: containerNode
,id:'sv'
, map: map
, ui: new DefaultUI()
, camera: {
position: {
x: -117.185087,
y: 32.715736,
z: 300,
spatialReference: {
wkid: 4326
heading: 90,
tilt: 77.5
.when(function(view){
self.setState({SceneView: view})
view.ui.padding = { top: 96, left: 21, right: 21, bottom: 0 }
if (window.matchMedia("(min-width: 770px)").matches) {
view.ui.components=["zoom", "navigation-toggle", "compass"];
view.on('click', function(e){
console.log('thi click has arrived: ' + JSON.stringify(e.mapPoint));
let searchResultGL = new GraphicsLayer()
self.setState({searchResultGL:searchResultGL});
view.map.add(searchResultGL)
render() {
const options = {
url: 'https://js.arcgis.com/4.10/'
return (
<div className="ESRIScene">
<EsriLoaderReact
options={options}
modulesToLoad={['esri/WebScene', 'esri/views/SceneView', 'esri/widgets/Locate', 'esri/layers/GraphicsLayer', 'esri/views/ui/DefaultUI']}
onReady={this.loadMap}
<MapOverlayPanel
ref ='mapOverlay'
sceneView={this.state.SceneView}
searchResultGL={this.state.searchResultGL}
resultPinDragable={true}
</div>
export default ESRIScene;
Any words of wisdom will be greatly appreciated.
Tyler
