Selection: How to implement fade out effect?
2669
10-26-2011 05:26 AM
AlexanderStepanov
New Contributor II
Hi all,
I appreciate if you could point me out to documentation/examples on how to implement the following:
in a web app, a user can make selection via drop down list. I would like to show the selected elements on the map with a highlight color which then fades out. ( so the selection shown only temporally ).
Thank you,
Alexander
JoeJeurissen
Dojo has a lot of built in animations such as fade out.
 dojo.fadeOut({
  node:"Your Element",
  duration:700,
  onEnd: function(){
   dojo.style("Your Element", "display", "none");
 }).play();
Some examples can be found here http://dojotoolkit.org/reference-guide/dojo/fadeOut.html
derekswingley1
I did something like this a while back in a dijit I built: http://swingley.appspot.com/maps/zoomto
Here's the relevant code:
    // serialize the extent to JSON, create a new extent to later pass to the map
    var featExt = new esri.geometry.Extent(ext.toJson());
    // listen to onExtentChange and then show a
    // graphic for the selected feature's extent
    this.extHandle = dojo.connect(this.map, 'onExtentChange', this, function() {
      var outline = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 173, 230, 1]), 3),
          symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, outline, new dojo.Color([0, 0, 128, 0])),
          extGraphic = new esri.Graphic(featExt, symbol);
      this.map.graphics.add(extGraphic);
      // fade out the graphic and remove it
      var fo = dojo.fadeOut({
        'node': extGraphic.getDojoShape().getNode(),
        'duration': 1500,
      // remove the graphic and clean up the event listeners
      // after the animation plays
      this.foHandle = dojo.connect(fo, 'onEnd', this, function() {
        this.map.graphics.remove(extGraphic);
        dojo.disconnect(this.extHandle);
        dojo.disconnect(this.foHandle);
      fo.play();
    // set the new extent
    this.map.setExtent(featExt, true);
Another option is to use dojox.gfx.fx to fade out the graphic. Here's an example:  http://jsfiddle.net/swingley/3VsgL/
ToddPayne
New Contributor II
 dojo.fadeOut({
  duration:700,
  onEnd: function(){
 }).play();
I would just add that the node we are most likely looking for can be referenced from the graphic object that represents the selected feature.  graphic.getDojoShape().getNode()
AlexanderStepanov
New Contributor II
Thank you, guys!
I will try to implement it and will summarize back on how it worked.
Alexander
AndrewCorcoran
New Contributor III
Just in case anyone finds this thread at a later date...
The first example swingley gives does not work in Internet Explorer (7, 8 or 9) but the second one using 'dojox.gfx.fx' does. Both versions work in Firefox. I haven't tested in Chrome.
Hope this helps someone as it has taken me quite a while to get it working in IE. Thank you very much swingley 🙂
