@model ModelLayer.Models.ReportModel
ViewData["Title"] = "Извештај";
<script src="http://cdnjs.cloudflare.com/ajax/libs/jquery/3.5.1/jquery.min.js"></script>
<link rel="stylesheet" href="http://code.jquery.com/ui/1.12.1/themes/smoothness/jquery-ui.css" />
<script src="http://code.jquery.com/ui/1.12.1/jquery-ui.min.js"></script>
<script src="~/js/bootstrap.min.js"></script>
<link href="~/css/bootstrap.min.css" rel="stylesheet" />
<link href="http://kendo.cdn.telerik.com/2020.2.513/styles/kendo.common.min.css" rel="stylesheet" />
<link href="http://kendo.cdn.telerik.com/2020.2.513/styles/kendo.default.min.css" rel="stylesheet" />
<script src="http://kendo.cdn.telerik.com/2020.2.513/js/kendo.all.min.js"></script>
<script src="~/js/kendo.aspnetmvc.min.js"></script>
<!--If Kendo is used it should be added before the report viewer.-->
<script src="~/Reports/telerikReportViewer-14.2.20.1021.min.js"></script>
<script src="~/Reports/telerikReportViewer.kendo-14.2.20.1021.min.js"></script>
<script>
window.rootUrl = '@Url.Content("~/")';
</script>
<style>
#reportViewer1 {
position: absolute;
left: 5px;
right: 5px;
top: 5px;
bottom: 5px;
overflow: hidden;
font-family: Verdana, Arial;
padding-left: 19%;
display: none
#reportForm {
margin-left: 16%;
box-shadow: 10px 10px 25px 0px rgba(0,0,0,0.75);
border-radius: 5px;
#loader {
position: fixed;
top: 50%;
right: 50%;
max-width: 20%;
max-height: 20%;
background-color: #fff;
background-image: url('~/img/loading.gif');
background-repeat: no-repeat;
background-position: center;
z-index: 10000000;
opacity: 0.4;
filter: alpha(opacity=40); /* For IE8 and earlier */
.k-widget .k-datepicker {
width: 100%;
</style>
<img src="~/img/loading.gif" id="loader" style="display:none" />
<link rel="stylesheet" href="http://js.arcgis.com/3.32/esri/css/esri.css">
<script src="http://js.arcgis.com/3.32/"></script>
<script>
This script is used to create the map on page load.
Layers are added to the map and the rest of the action is completed on Print button click
var map;
var imageUrl, imageLegendUrl;
var minParc, fullP, sentScale, reportType, globalParcel;
var mainReportParameters = {};
var mainReport;
var documentType;
var returnScaleValue;
require(["esri/map",
"esri/config",
"esri/dijit/Basemap",
"esri/dijit/BasemapLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/tasks/QueryTask", "esri/tasks/query",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol", "esri/Color", "esri/graphic",
'esri/symbols/SimpleMarkerSymbol',
'dojo/_base/array',
'esri/geometry/Extent',
"esri/dijit/Print",
"esri/tasks/PrintTemplate",
"dojo/dom", "esri/tasks/PrintTask", "esri/tasks/PrintParameters",
"dojo/on",
"dojo/domReady!"],
function (Map, esriConfig, Basemap, BasemapLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, QueryTask, Query, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic, SimpleMarkerSymbol, array, Extent, Print, PrintTemplate, dom, PrintTask, PrintParameters, on) {
map = new Map("map", {
basemap: new Basemap({
layers: [new BasemapLayer({
url: 'http://10.0.0.10/arcgis/rest/services/Podlogi_Izvodi_500/MapServer'
extent: new Extent({
'xmin': 7530850.8094923375,
'ymin': 4647910.133863028,
'xmax': 7536270.404088697,
'ymax': 4655172.52276435,
'spatialReference': {
'wkid': 6316
sliderStyle: 'small',
zoom: 5,
var secondLayer = new ArcGISDynamicMapServiceLayer("http://10.0.0.10:6080/arcgis/rest/services/Karpos_Vector_Izvodi/MapServer", {
"opacity": 1
map.addLayer(secondLayer);
map.on("load", selectRoute);
function selectRoute() {
console.log("Security patch #523532.12");
$(document).ready(function () {
// - button for report printing
clicks = function (e) {
$("#loader").show();
$("#reportForm").hide();
reportType = $("input[name='reportButton']:checked").val();
globalParcel = ($("#buildParcelID").val()).trim();
printMap();
selectScale = function () {
returnScaleValue = document.getElementById("chooseScale").value;
map.setScale(returnScaleValue);
console.log("The returned scale value is:", returnScaleValue);
function printMap() {
require(["dojo/on", "esri/config", "esri/tasks/QueryTask", "esri/tasks/query", 'esri/symbols/SimpleMarkerSymbol', "esri/symbols/SimpleLineSymbol", "esri/Color", 'esri/geometry/Extent', "esri/tasks/PrintTask", "esri/tasks/PrintParameters", "esri/tasks/PrintTemplate", "dojo/domReady!"],
function (on, esriConfig, QueryTask, Query, SimpleMarkerSymbol, SimpleLineSymbol, Color, Extent, PrintTask, PrintParameters, PrintTemplate) {
console.log("globalParcel :: " + globalParcel + " reportType :: " + reportType + " globalScale :: " + sentScale);
var queryTask = new QueryTask("http://app.gdi.mk:6080/arcgis/rest/services/karpos/Karpos_Vector_Izvodi/MapServer/1");
var query = new Query();
query.where = "code ='" + globalParcel + "'";
query.outSpatialReference = map.spatialReference;
query.returnGeometry = true;
query.outFields = ["*"];
queryTask.execute(query).then(zoomToRoute);
// ZOOM TO ROUTE
function zoomToRoute(features) {
var map = this.map;
map.graphics.clear();
var pointSymbolNew = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 255, 255]), 1), new Color([255, 0, 127, 1]));
var selectedFeature = features.features;
selectedFeature[0].setSymbol(pointSymbolNew);
map.graphics.add(selectedFeature[0]);
console.log("map.setScale(returnScaleValue)", returnScaleValue)
//map.setScale(sentScale);
//console.log("map.setScale(sentScale)", sentScale)
map.centerAt(selectedFeature[0].geometry);
setTimeout(printImage, 5000);
// ZOOM TO ROUTE
// SET COOKIE
function setCookie(cname, cvalue, exdays) {
var d = new Date();
d.setTime(d.getTime() + (exdays * 24 * 60 * 60 * 1000));
var expires = "expires=" + d.toGMTString();
document.cookie = cname + "=" + cvalue + ";" + expires + ";path=/";
// SET COOKIE
// PRINT IMAGE
function printImage() {
var printTask;
var params = new PrintParameters();
printTask = new PrintTask('http://10.0.0.10:6080/arcgis/rest/services/Print_legend_included/GPServer/Export%20Web%20Map');
params.map = map;
var template = new PrintTemplate();
template.format = 'JPG';
template.layout = 'MAP_ONLY';
template.preserveScale = false;
params.template = template;
printTask.execute(params, printResult);
// PRINT IMAGE
// PRINT RESULT
function printResult(evt) {
imageUrl = evt.url;
setCookie('imageUrl', imageUrl, 1);
if (reportType == 1) {
printReport();
if (reportType == 2) {
var printTaskLegend;
var printPars = new PrintParameters();
printPars.map = map;
printTaskLegend = new PrintTask('http://10.0.0.10:6080/arcgis/rest/services/Print_legend_included/GPServer/Export%20Web%20Map');
params.map = map;
template.layout = 'Print_legend_included';
template.preserveScale = true;
printPars.template = template;
printTaskLegend.execute(printPars, printImageLegend);
// PRINT RESULT
// PRINT IMAGE LEGEND
function printImageLegend(evt) {
imageLegendUrl = evt.url;
setCookie('imageLegendUrl', imageLegendUrl, 1);
printReport();
// PRINT REPORT FUNCTION
function printReport() {
var trafficValString = 'Паркирање во рамките на сопствена парцела'
if ($("#trafficConditionsID").val() == '') {
trafficVal = trafficValString;
} else {
trafficVal = $("#trafficConditionsID").val();
var miscValString = 'Овој извод е основа за изработка на основен проект/архитектонско - урбанистички проект, кој пак е потребен во постапката за добивање одобрение за градење. Изработката на проектантската документација да е во согласност со законската и подзаконската регулатива од областа.'
if ($("#miscelanousID").val() == '') {
miscVal = miscValString;
} else {
miscVal = $("#miscelanousID").val();
documentType = "KarposSingleReportFINAL.trdp"
"reportNumberID_par": $("#reportNumberID").val(),
"dateID_par": $("#dateID").val(),
"planNumberID_par": $("#planNumberID").val(),
"dupDescription_par": $("#DUPid").val(),
"dupDecision_par": $("#odlukaDup").val(),
"dupDate_par": $("#datumDup").val(),
"klasaNamena_par": $("#klasaNam").val(),
"buildParcel_par": minParc,
"street_par": $("#streetNameID").val(),
"houseNumber_par": $("#houseNumberID option:selected").val(),
"municipality_par": $("#KBRid").val(),
"detailsDocument_par": $("#detailsDocumentID").val(),
"municipalParcel_par": $("#municipalParcelID").val(),
"scale_par": $("#scale option:selected").text(),
"imageUrl_par": readCookie("imageUrl")
documentType = "KarposDoubleReport.trdp"
"urbanistickaParc_par": $("#urbanistickaParcela").val(),
"povrsinaUrbParc_par": $("#povrsinaUrbParc").val() + " м2",
"povrsinaGabarit_par": $("#povrsinaGabarit").val() + " м2",
"procentIzgradenost_par": $("#procentIzgradenost").val() + "%",
"maxIzgPovr_par": $("#maxIzgPovr").val() + " м2",
"koefIsko_par": $("#koefIsko").val(),
"maxDozH_par": $("#maxDozH").val() + " м",
//"maxHSleme_par": maxSleme,
"brojParkingMesta_par": $("#brParkingMesta").val(),
"drUslovi_par": miscVal,
"soobUslovi_par": trafficVal,
"imageUrl_par": readCookie("imageUrl"),
"imageLegendUrl_par": readCookie("imageLegendUrl")
$("#reportViewer1").show();
$("#loader").hide();
$("#reportViewer1").telerik_ReportViewer({
serviceUrl: "/karposreports/api/reports/",
reportSource: {
report: documentType,
parameters: mainReportParameters
viewMode: telerikReportViewer.ViewModes.INTERACTIVE,
scaleMode: telerikReportViewer.ScaleModes.SPECIFIC,
scale: 1.0,
enableAccessibility: true,
sendEmail: { enabled: false },
ready: function () {
//this.refreshReport();
</script>
<div>
<div>
<div class="sidebar" data-color="azure" data-background-color="white" />
Tip 1: You can change the color of the sidebar using: data-color="purple | azure | green | orange | danger"
Tip 2: you can also add an image using data-image tag
<div class="logo">
<a href="https://karpos.gov.mk/" class="simple-text logo-normal">
Општина Карпош
</a>
</div>
<div class="sidebar-wrapper">
<ul class="nav">
<li class="nav-item active">
<a class="nav-link" asp-controller="DUP" asp-action="PrintReport">
<i class="fa fa-plus-circle" aria-hidden="true"></i>
<span>Подготви извештај</span>
</a>
</li>
<li class="nav-item ">
<a class="nav-link" href="http://62.162.113.130:6080/karposgis/">
<i class="material-icons">content_paste</i>
<p>ГИС Прегледник</p>
</a>
</li>
</ul>
</div>
</div>
</div>
<div id="reportForm">
<div class="col-sm-6">
<label for="">Размер</label>
<select class="form-control" id="chooseScale" name="scale" onmouseup="selectScale()">
<option value="1000" selected>1:1000</option>
<option value="2500">1:2500</option>
</select>
</div>
</div>
</div>
<div id="reportViewer1" class="k-widget">
loading...
</div>
I took your code, placed it inside my view. I get the values, they are correct but the printTask is not working now for some reason. Also, it's kind of an issue that initially the dropdown value is 1:1000 but unless I actually click the dropdown, the value is empty.
