SPLIT POLYLINE
1219
07-25-2016 11:33 PM
bharathreddy
Hello all,
I need a help on how to split polyine using arcgis javascript
FC_Basson
MVP Regular Contributor
API 3.17: You can split/cut geometries using the geometryEngine cut method [esri/geometry/geometryEngine | API Reference | ArcGIS API for JavaScript 3.17]OR with the GeometryService cut method [GeometryService | API Reference | ArcGIS API for JavaScript 3.17]
API 4.0: Cut method: geometryEngine | API Reference | ArcGIS API for JavaScript 4.0
bharathreddy
Do you have any code
