To remove powered by esri logo
9338
06-05-2012 12:37 AM
PramodHarithsa1
Occasional Contributor II
What is actually causing the logo to appear?
I am using api and base map from esri's server ! How can i remove it.. ?
How do i eliminate this dependancy?
nicogis
MVP Frequent Contributor
Display the esri logo on the map. The default value is true.
You can set false
map = new esri.Map("map", {    extent: initExtent,    logo:false  });
nicogis
You can set false
PramodHarithsa1
Thanks Domenico,
and how do i replace the logo with some other image?
nicogis
PramodHarithsa1
SrikanthNarra
Hi Mr.Pramod,
   Apply the style to map
<style type="text/css">
         .map .logo-med, .map .logo-sm {
             background-image: url("http://mapserv.utah.gov/CDN/images/agrc_map_logo_small.png") !important;/*your logo */
             border:0;
             bottom: 5px;
             cursor: pointer;
             height: 25px !important; /* size of your image */
             position: absolute;
             right: 5px;
             width: 48px !important;/* size of your image */
             z-index: 49;
</style>
