Chris,
The changes go in the main.js
define([
'dojo/query',
'dojo/dom',
'dojo/dom-class',
'dojo/dom-style',
'dojo/dom-attr',
'esri/config',
'esri/layers/FeatureLayer',
'esri/InfoTemplate',
'esri/graphic',
'esri/dijit/Geocoder',
'esri/dijit/LocateButton',
'esri/dijit/Legend',
'esri/tasks/GeometryService',
'esri/geometry/Extent',
'esri/layers/ArcGISDynamicMapServiceLayer',
'esri/layers/ArcGISTiledMapServiceLayer',
'bootstrap-map-js/js/bootstrapmap',
'dojo-bootstrap/Collapse',
'dojo-bootstrap/Dropdown',
'dojo-bootstrap/Modal',
'dojo-bootstrap/Alert',
'dojo/domReady!'
], function(
query, dom, domClass, domStyle, domAttr,
esriConfig, FeatureLayer, InfoTemplate, Graphic, Geocoder, LocateButton, Legend, GeometryService,
Extent, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
BootstrapMap
'use strict';
/* The proxy comes before all references to web services */
/* Files required for security are proxy.config, web.config and proxy.ashx
- set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
(Roles are not required)
The proxy section is defined on the ESRI sample. I have included it as
part of the documentation that reads that the measuring will not work.
I thought that might be important.
// Proxy Definition Begin
//identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
//If this null or not available the project and lengths operation will not work.
// Otherwise it will do a http post to the proxy.
esriConfig.defaults.io.proxyUrl = "proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = false;
// Proxy Definition End
// declare geometry service
esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
//Chris's options
var initialExtent = new Extent({
"xmin": 777229.03,
"ymin": 1133467.92,
"xmax": 848340.14,
"ymax": 1185634.58,
"spatialReference": {
"wkid": 3435
// app configuration
var config = {
mapOptions: {
showAttribution: false,
sliderStyle: "small",
extent: initialExtent,
logo: false,
sliderPosition: 'bottom-right'
citizenRequestLayerUrl: 'http://maps.decaturil.gov/arcgis/rest/services/test/StreetSignTest/FeatureServer/0',
infoTemplate: {
title: '<b>Request ${objectid}</b>',
content: '<span class="infoTemplateContentRowLabel">Date: </span>' +
'<span class="infoTemplateContentRowItem">${requestdate:DateFormat}</span><br><span class="infoTemplateContentRowLabel">Phone: </span>' +
'<span class="infoTemplateContentRowItem">${phone:formatPhoneNumber}</span><br><span class="infoTemplateContentRowLabel">Name: </span>' +
'<span class="infoTemplateContentRowItem">${name}</span><br><span class="infoTemplateContentRowLabel">Severity: </span>' +
'<span class="infoTemplateContentRowItem">${severity:severityDomainLookup}</span><br><span class="infoTemplateContentRowLabel">Type: </span>' +
'<span class="infoTemplateContentRowItem">${requesttype:requestTypeDomainLookup}</span><br><span class="infoTemplateContentRowLabel">Comments: </span>' +
'<span class="infoTemplateContentRowItem">${comment}</span>'
// app globals
var app = {};
app.collapseMenuToggleButton = dom.byId('collapseToggleButton');
app.startEditAlert = dom.byId('startEditAlert');
app.sidebar = dom.byId('sidebar');
app.attributesModal = query('#attributesModal');
app.requestTypeSelect = query('#attributesModal [name="requesttype"]')[0];
// TODO: get these from the feature layer on load
app.severityFieldDomainCodedValuesDict = {
'0': 'General Nuisance',
'1': 'Important To Resolve Soon',
'2': 'Critical Issue'
app.requestTypeFieldDomainCodedValuesDict = {
'0': 'Abandoned Vehicle',
'1': 'Animal Services',
'2': 'Driveway Infraction',
'3': 'Flooding',
'4': 'Graffiti Removal',
'5': 'Homeless Nuisance',
'6': 'Illegal Dumping',
'7': 'Parking Violation',
'8': 'Plant/Tree Complaint',
'9': 'Pothole Obstruction',
'10': 'Roadway Danger',
'11': 'Sidewalk Danger',
'12': 'Streetlight Broken',
'13': 'Street Sign Missing/Damaged',
'14': 'Trash Removal',
'15': 'Water Leak',
'16': 'Yard Waste Removal'
// NOTE: popup formatting functions must be globals
window.severityDomainLookup = function (value, key, data){
return app.severityFieldDomainCodedValuesDict[value];
window.requestTypeDomainLookup = function (value, key, data){
return app.requestTypeFieldDomainCodedValuesDict[value];
window.formatPhoneNumber = function (value, key, data){
return value ? '<a href=\'tel:' + value + '\'>' + value + '</a>' : '';
// initialize the request type drop down
var initAttributeForm = function() {
var options = [];
for (var key in app.requestTypeFieldDomainCodedValuesDict) {
if (app.requestTypeFieldDomainCodedValuesDict.hasOwnProperty(key)) {
options.push('<option value="' + key + '">' + app.requestTypeFieldDomainCodedValuesDict[key] + '</option>');
app.requestTypeSelect.innerHTML = options.join('');
// initialize the map and add the feature layer
// and initialize map widgets
var initMap = function() {
app.map = BootstrapMap.create('map', config.mapOptions);
var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
app.map.addLayer(tiled);
// add operational layer
var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", {
"opacity": 0.5
app.map.addLayer(operationalLayer);
app.citizenRequestLayer = new FeatureLayer(config.citizenRequestLayerUrl, {
mode: FeatureLayer.MODE_ONEDEMAND,
infoTemplate: new InfoTemplate(config.infoTemplate),
outFields: ['*']
app.map.addLayer(app.citizenRequestLayer);
app.geocoder = new Geocoder({
map: app.map,
autoComplete: true,
arcgisGeocoder: {
placeholder: 'Address or Location'
'class': 'geocoder'
}, 'geocoder');
app.geocoder.startup();
// Begin geolocate button
// add geolocate button to find the location of the current user
app.map.on("load", function () {
app.locateButton = new LocateButton({
map: app.map,
highlightLocation: true,
useTracking: true,
enableHighAccuracy: true
}, 'locateButton');
app.locateButton.clearOnTrackingStop = true;
app.locateButton.startup();
app.locateButton.locate();
// End geolocate button
app.legend = new Legend({
map: app.map,
layerInfos: [{
title: 'Street Signs and Supports',
layer: app.citizenRequestLayer
}, 'legend');
app.legend.startup();
// TODO: other widgets, etc
// hide nav dropdown on mobile
var hideDropdownNav = function(e) {
if (query('.navbar-collapse.in').length > 0) {
e.stopPropagation();
app.collapseMenuToggleButton.click();
// temporarily show alert when starting edits
// and then start listening for a map click
var startCaptureRequest = function(severity) {
var listener;
// NOTE: once user has clicked 'x' to dismiss
// this alert, it will no longer show up
domStyle.set(app.startEditAlert, 'display', '');
setTimeout(function() {
domStyle.set(app.startEditAlert, 'display', 'none');
}, 3000);
// save map point in app global and
app.currentSeverity = severity;
listener = app.map.on('click', function(e) {
listener.remove();
// show form to collect incident report
app.currentGeometry = e.mapPoint;
app.attributesModal.modal('show');
var stopCaptureRequest = function() {
app.currentSeverity = null;
app.currentGeometry = null;
// get attributes from form and submit
var submitIncidentReport = function() {
var attributes = {
// TODO: not sure if this is needed
requestreceived: null
var currentDate = new Date();
var graphic;
if (!app.currentSeverity || !app.currentGeometry) {
return;
graphic = new Graphic(app.currentGeometry);
attributes.severity = parseInt(app.currentSeverity, 10);
query('#attributesModal input, #attributesModal select, #attributesModal textarea').forEach(function (formInput) {
attributes[formInput.name] = formInput.value;
attributes.requesttype = parseInt(attributes.requesttype, 10);
attributes.requestdate = Date.UTC(currentDate.getUTCFullYear(), currentDate.getUTCMonth(),
currentDate.getUTCDate(), currentDate.getUTCHours(), currentDate.getUTCMinutes(),
currentDate.getUTCSeconds(), 0);
graphic.setAttributes(attributes);
stopCaptureRequest();
// console.log(attributes);
app.citizenRequestLayer.applyEdits([graphic], null, null).then(function(response) {
console.log(response);
// wire up the DOM events
var initEvents = function() {
// listen for map clicks once severity is chosen
query('.report-btn-group .dropdown-menu a').on('click', function(e) {
e.preventDefault();
startCaptureRequest(domAttr.get(e.target, 'data-value'));
// TODO show the feedback modal
query('a[href="#feedback"]').on('click', function(e) {
e.preventDefault();
query('#feedbackModal').modal('show');
// hide drop down nav after clicking on a link
query('.navbar-collapse a').on('click', function(e) {
hideDropdownNav(e);
// change the basemap
query('#basemapDropdown a').on('click', function(e) {
var basemapName = domAttr.get(e.target, 'data-name');
if (basemapName && app.map) {
app.map.setBasemap(basemapName);
// toggle the sidebar
query('#sidebarToggleButton').on('click', function(e) {
// make sure sidebar is same height as the map
if (app.map.height) {
domStyle.set(app.sidebar, 'height', app.map.height + 'px');
domClass.toggle(window.document.body, 'sidebar-open');
hideDropdownNav(e);
// submit or cancel request and hide modal
query('#attributesModal .btn').on('click', function(e) {
var target = e.target;
if (target.innerText === 'Submit') {
submitIncidentReport();
app.attributesModal.modal('hide');
query('#feedbackModal .btn').on('click', function(e) {
// NOTE: this is not implemented in sample app
query('#feedbackModal').modal('hide');
// clear current edit session globals
app.attributesModal.on('hidden.bs.modal', stopCaptureRequest);
// finally, start up the app!
initAttributeForm();
initMap();
initEvents();
return app;
