At 4.3, view.hitTest() method does not work on a esriGeometryMultipoint service. I set up a demo of the problem, but I couldn't find an ESRI sample service with multipoint geometry, so you'll have to supply your own. My test map service isn't public. Anyway, insert your multipoint geometry map service url and you will see that the cursor stays as the default when hovering over a multipoint feature but works correctly when hovering over a regular point. Or maybe I'm doing something wrong? Rene Rubalcava
JS Bin - Collaborative JavaScript Debugging
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<meta name="description" content="[Get started with MapView - Create a 2D map - 4.3]">
<title>Get started with MapView - Create a 2D map - 4.3</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<script src="https://js.arcgis.com/4.3/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"dojo/domReady!"
], function(Map, MapView, FeatureLayer) {
var map = new Map({
basemap: "streets"
var view = new MapView({
container: "viewDiv",
map: map,
center: [-84.511, 39.092],
zoom: 15
var points = new FeatureLayer({
url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0"
map.add(points);
view.on('pointer-move', function(evt){
view.hitTest({x: evt.x, y: evt.y}).then(changeCursor);
function changeCursor(response){
if (response.results.length > 0){
document.getElementById("viewDiv").style.cursor = "pointer";
} else {
document.getElementById("viewDiv").style.cursor = "default";
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
