So, I'm starting to think CORS support is broken in JS API 3.21, or does not support using a webadaptor with windows integrated authentication.
Has anyone have a setup like this working? If so can you share how you made it work? Is there any documentation about this combo?
I will try to be clear and concise with the details.
Server: windows 2012, with webadaptor with windows authentication, arcgis server 10.5, authentication web tier, windows authentication; webadaptor with windows authentication on.
Web app with esri js 3.21, with windows authentication (same domain).
My web app works fine. There's a first request that fails with 401:
https://server/webadaptor/rest/info?f=json
Then requests to my mapservice work fine, and use callback=dojo.io.script.jsonp_dojoIoScript1._jsonpCallback in the querystring.
When I add my server to esriConfig.defaults.io.corsEnabledServers, things break.
There is only 1 request to my mapservice.
It fails with 401 Unauthorized. And nothing else is loaded from the webadaptor:
https://server/webadaptor/rest/services/servicename/MapServer?f=json&dpi=96&transparent=true&format=...
As you can see, no callback is used.
Request headers:
Accept:*/*
Accept-Encoding:gzip, deflate, br
Accept-Language:pt-PT,pt;q=0.8,en-US;q=0.6,en;q=0.4,es;q=0.2
Cache-Control:no-cache
Connection:keep-alive
Content-Type:application/x-www-form-urlencoded
Host:sigims2.edia.pt
Origin:https://dev1.domain.pt
Pragma:no-cache
Referer:https://dev1.domain.pt/
User-Agent:Mozilla/5.0 (
Response Headers:
Access-Control-Allow-Origin:*
Content-Length:1293
Content-Type:text/html
Date:Fri, 18 Aug 2017 14:54:17 GMT
Server:Microsoft-IIS/7.5
WWW-Authenticate:Negotiate
WWW-Authenticate:NTLM
X-Powered-By:ASP.NET
Request:
Request URL:https://server/webadaptor/rest/services/mapservice/MapServer?f=json&dpi=96&transparent=true&format=p...
Request Method:GET
Status Code:401 Unauthorized
Remote Address:x.x.x.x:443
Referrer Policy:unsafe-url
IIS Log says no username is given in the request, and the error is 401 2 5 2.
Any help much appreciated.
Cheers,
Duarte
