Why am I getting require is not defined in my jsbin code?
5968
07-30-2015 07:10 AM
ChrisSergent
Regular Contributor III
I was testing my application and the text value does not display in Google Chrome, the most recent version. So, I then tested my code in jsbin at: JS Bin - Collaborative JavaScript Debugging  and I receive the following error:
I searched on here for require is not defined and did not see anything similar.
What's causing this error?
ReneRubalcava
Looks like jsbin doesn't like http links, so change script tag to https
<script src="https://js.arcgis.com/3.14"></script>
ChrisSmith7
Chris,
Does this work ok for you?
Wrong link... updating...
ChrisSergent
It does, but that's 3.8. Did you notice something?
ChrisSmith7
Updated link!
I took a working project and inserted your code - no errors, at least.
ReneRubalcava
ChrisSmith7
Nice catch! You can also just set the URL back to http to avoid mixed content - that seems to work, too, which is why it's working in my sample - https://community.esri.com/external-link.jspa?url=http://jsbin.com/dabamobuga/1/edit?html,console,ou...
