Why WebScene can tilt larger than 90 degree but Javascript 4.0 API cannot?
1178
08-25-2016 10:01 PM
MarkLam1
Hi all,
I am now writing a Web App using 4.0 API. I loaded a WebScene using the API and find that the tilt behavior is different than of opening the WebScene with Scene view in Portal for ArcGIS. The tilt degree for the API is 0 ~ 90 while that of Scene view is 0 ~ 180. It is necessary in my application to have a camera view with tilt > 90 degree. Kindly if there is any solution.
JohnGrayson
SceneView.constaints doc says 0.5 to 179.5 degrees. Have you tried setting the constraints.tilt.max explicitly?
JohnGrayson
MarkLam1
Thx a lot! It works great!
