Zoom rectangle not visible navigation toolbar javascript api 3.10 IE 11
1426
08-15-2014 12:44 PM
Marc-OlivierEthier
New Contributor II
I'm using the javascript API 3.10 with Internet Explorer 11. When using the navigation toolbar zoom in button, the red rectangle feedback doesn't show up.
The problem is with the navigation toolbar because if I don't use it, when I hold the Shift key while zooming, the rectangle show up.
I can reproduce the problem with this sample: Navigation toolbar
Is someone have a workaround for this ?
Thanks‌
NicholasHaney
New Contributor III
Not sure what is causing this. I can't reproduce it in IE.
JonathanUihlein
Thanks for the feedback. I was able to recreate this issue and it is indeed a bug.
This will be fixed in the next release.
Marc-OlivierEthier
New Contributor II
Thanks, I have found a workaround: if I add
<meta http-equiv="X-UA-Compatible" content=IE=9, IE=8, IE=7">
in the head section of the main page, the red rectangle feedback is visible.
Thanks
AdrianMarsden
Occasional Contributor III
Promise?  As it's been well and truly documented here on numerous threads since IE10 days, so not a new issue in anyway.
previous threads
https://community.esri.com/message/334727?sr=search&searchId=e386cdbb-ca50-435e-b70b-6847d8485f0e&se...
https://community.esri.com/message/78133?sr=search&searchId=e386cdbb-ca50-435e-b70b-6847d8485f0e&sea...
https://community.esri.com/message/387162?sr=search&searchId=e844ff85-f58e-42ff-9975-61f3f4122b2e&se...
JonathanUihlein
Seeing as this is a Dojo issue at its core, there's not much we can do other than the workarounds suggested in that first thread.
We are upgrading to Dojo 1.10.0 in the next release so the problem should be fixed.
Also, one of those threads has nothing to do with this bug, not sure why you linked it.
