Zoom to Query Results
5745
6
06-04-2013 09:07 AM
TrevorWeiland
New Contributor III
HELP!
I am working on a JavaScript web page that does two things:
1) Query a rest service for the attribute information from a single record and then presents it in a table.
2) Builds a map and zooms to the results from the query.
I used the "Query State Info without Map" to start with and to accomplish the first task.  I added a map (basemap plus a couple of additional layers for display).  However, I am unable to extract the geometry from the query results as a point to use when creating the map.
The rest service I'm using for the query is not exposed to the internet so I have reworked and simplified my code (using just the sample code and internet services) to the basics so I can learn what I'm doing and apply it to my actual page:
<!DOCTYPE html> <html>  <head>   <meta http-equiv="Content-Type" content="text/html; charset=utf-8">   <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">   <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices-->   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">   <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">   <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">   <title>Query State Info with Map</title>   <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>   <script>    dojo.require("esri.tasks.query");    dojo.require("esri.map");     var queryTask, query, centerPoint, stateName;     var stateName = "Colorado" /* stateName for QueryTask */     function init() { /* Setup query */     queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5");     query = new esri.tasks.Query();     query.returnGeometry = true;     query.outSpatialReference = new esri.SpatialReference({wkid : 102100});     query.outFields = ["STATE_NAME","SQMI","SUB_REGION"];     query.text = stateName;          queryTask.execute(query, showResults);    }     function showResults(results) {     var s = "";     for (var i=0, il=results.features.length; i<il; i++) {      var featureAttributes = results.features.attributes;      for (att in featureAttributes) {       s = s + "<b>" + att + ":</b> " + featureAttributes[att] + "<br />";      }     }     dojo.byId("info").innerHTML = s; /* Extract Geometry From Query */     centerPoint = new esri.geometry.Point(getPoint(results)); //Does NOT work- Actual use will be a point layer //    centerPoint = [-122.45, 37.75] //fake point for testing /* Build Map */     map = new esri.Map("map",{ basemap: "topo", center:centerPoint, zoom:13 });      map.addLayer(new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer", { "opacity":0.2, spatialReference: map.spatialReference })); /* Add ESRI Census Map */    }    dojo.ready(init);   </script>  </head>  <body class="claro">   <div id="info" style="padding:5px; margin:5px; background-color:#eee;"></div>   <div id="map"></div>  </body> </html>
Can someone please help me understand how to extract the geometry of the results to a variable that can then be used to create a center-point in a map?
Thank you,
AdamSkoog
New Contributor III
A better way to do this would be to zoom to the extent of your graphics and expand a bit to zoom out.
function showResults(results) {         // This takes the graphics array you get back from your query and         // gets the overall extent for them. Make sure return geometry is set to          // true in your query.         var extent = esri.graphicsExtent(results.features);          // Use that to set the extent, 1.5 is something I use in my app, but play with         // it to find a setting you like, setting the second parameter to true will get you an extend         // that is at the closest level of your cached service.         map.setExtent(extent.expand(1.5), true); }
I noticed in your code your map isn't initialized yet at this point. Your map initialize code would change to the
following and you would skip the map.setExtent above.
        map = new esri.Map("map",{ basemap: "topo", extent: extent })
Hopefully this helps you out a bit. 🙂
AdamSkoog
New Contributor III
TrevorWeiland
New Contributor III
I think I inserted your code correctly, however, if I have
var extent = esri.graphicsExtent(results);
anywhere in the "showResults" function, the map fails- even if I don't use extent anywhere else.
JohnGravois
to solve this problem you have to dig into the results in order to get a reference to the geometry of the returned polygon itself (ie.  "results" is a generic featureset, "results.features" is an array of graphics and "results.features.geometry" is a geometry object for a specific graphic, where "i" refers to the index position of the item within an array).
in order to use our utility method to return the extent of a collection of graphics, you would do this
here's how to retrieve the same extent by calling the getExtent method of a single polygon geometry object (this works because there was only one graphic in the array)
//features[0] will always be the first item in an array
var extent = results.features[0].geometry.getExtent();
map = new esri.Map("map",{ basemap: "topo", extent: extent });
here's how you use the polygon geometry to retrieve a valid point from within the geometry instead
//in order to call the getPoint method of a polygon geometry object, you have to pass index positions to articulate which ring and specific point you want
centerPoint = results.features[0].geometry.getPoint(0,0);
i've always found it really helpful to set breakpoints within the callback so that i can inspect the results and use the console interactively to figure out how to get a reference to exactly what i need so that i can go back afterwards and modify the source code
[ATTACH=CONFIG]24992[/ATTACH]
hopefully all that helps!
AdamSkoog
New Contributor III
jgravois was right, I was typing to fast and forgot to add the features property on there. I editted the post to reflect what it should be.
TrevorWeiland
New Contributor III
thank you both very much.
JohnGravois
you're very welcome.  please feel free to mark Adam's post as the answer.
