Hi Amy,
Like I said, it's not very straight forward to change the symbology. This is something we usually would have you purchase as a service. I'm not in sales, so I cannot say how much it would cost--or if it would cost you money, depending on your account and credits etc. You can inquire from your local distributor. If a service is not possible (although it would be ideal, because we would do the work for you), there's a second option. If you could log a technical support case, it would really be more helpful for both of us. You can request that it be assigned to me. This way, I could address your needs more quickly--you can contact me directly, and we could arrange phone calls and screen sharing sessions. If that is possible, please log a case. In the mean time, I will try to describe what I can here.
For starters, you can take the INT1.style file, found at C:\Program Files (x86)\ArcGIS\Desktop10.3\Styles\ copy it, and paste it to a working directory you have full read-write access to. You may need to change the file not to be "read only."
Through the Style Manager, you can open the copy of the INT1 style, and edit the representation rules (be sure to edit the rules, and not the representation markers). Here you can change the symbol size, color, or make modifications to the rule. This is the easy part! Managing style contents—Help | ArcGIS for Desktop
Here's a quick tutorial on working with cartographic representations: Introduction to the cartographic representations tutorial—Help | ArcGIS for Desktop This can be a daunting task, as there are hundreds of representation rules. I suggest only changing/modifying the rules you need to change, and ignore the others. This will save you time. I don't recommend deleting rules, as this may have and undesired result when running the Calculate tool. I'm hoping we can address all your symbology requests with changes to the style. Once you're satisfied with the changes in the style file, rename the original INT1 style file something like "INT1_install", and add your modified INT1 style file to the install location C:\Program Files (x86)\ArcGIS\Desktop10.3\Styles. You can test your changes by using the Update command. Updating nautical symbology—Help | ArcGIS for Desktop
Changing the behind-the-scenes file of which SQL statement assigns which representation to which feature is much more complex. I'm hoping you won't need to do this, as this isn't something intended for you to modify. That's not to say you can't, but you need to know how to modify an XML document. If it comes to it, I'd feel more confident describing to you how to do this in person, rather than an email. It can be a bit confusing. Once you get the hang of it, it's not that hard to do.
When you're done modifying the symbols, you can make a new data model based on the changes you made. I have the steps on how to do this. It is very easy to do, however you must follow the steps exactly. I have this in a word document--I can't attach it here, I'll find a way to send it to you.
Lastly, you can make a new chart product to view the changes were successful. I think that as you go, you'll find more things to change. The more you do it, the more familiar you'll become with it, and it'll get easier for you.
Let me know about the technical support case.
Thanks and regards,
Andrea
