Error Opening Feature Class
14784
14
11-17-2016 12:17 AM
JoelAnampiu
I took a GIS class a while back and am coming back to working with Arcmap. I don't why I can add some shapefiles and not others. All the other files are located in the general zip file as well (SHX, SBN, SBX, etc.). When I try to add some file it'll say error opening feature class and for a few it will also say could not add the specified data object to the map. I figured maybe there are not enough features so maybe I'll try to convert it from a feature class to a raster? I've had to uninstall the program once because somehow the data source for some my shapefiles were missing (?), thus it was not showing up. Problem fixed on that front but now I have to get these shapefiles for my map. I'm trying to add HUC-12 data from the geospatial gateway showing sub watersheds.
JoelAnampiu
I figured it out. Thanks for the assistance.
JoelAnampiu
Nevermind I figured it out. Thank you for the assistance!
DanPatterson_Retired
It would be nice to provide the solution given a lot of possibilities were already covered
JoelAnampiu
For some reason the archivator files weren't visible. I made sure that everything was together and visible in separate folders and voila.
BeressaEdessa
Hi Joel,
I am having similar challenges that you had and come across your post. I am sorry, I couldn't figure out the solution. can you please kindly help me out how to fix the problem?
Thanks
Beresa
