Within ArcMap, I create a new file GDB and then create a Feature Dataset. I then right click on the feature dataset and select Import > S-57 to Geodatabase and I get the following error: "There was a problem loading the product configuration file"
Where do I set this configuration file and what is the likely problem?
I'm new to the Nautical Solution, and it seems like a steep learning curve. Any help would be appreciated, thanks.
Sorry for the long delay in replying to your last post. This is a known defect with the File Geodatabase. If you setup an ENC product geodatabase on SQL Express using the Desktop workflow, you should have success importing and exporting an ENC cell.
Could you please explaine step by step how to import S-57 charts into geodatabase (enterprise on MS SQL Server 2008)? Does it matter if ArcGIS Server 10.0 installed and ArcGIS for Maritime: Charting is younger - 10.1 (for ArcGIS Desctop 10.1)? Thanx.
