Is there a way to convert from polygon to points based on population of the polygon similar to dot density symbology
2739
04-18-2017 06:09 AM
ChrisRichmond
I can display the number of patients by census tracts using dot density but I also want to display expected percent change in the future.  I don't think I can do both of those with symbology, is there a way to convert from a polygon to points based on the number of patients by census tract so that I have a feature class that looks like a dot density?
AbdullahAnter
Occasional Contributor III
You need to Use Create Random Points tool Create Random Points—Help | ArcGIS Desktop :
but before that , create short integer field and calculate the count of point (Value / the value per one point )
and use this field in Create Random Point tool as number_of_points_or_field
and don't forget to define your polygon feature class as constraining_feature_class
ChrisRichmond
AbdullahAnter
ChrisRichmond
Thank you, don't know why I didn't think of that but that worked perfectly for what I was needing.  Thanks again Abdullah
AbdullahAnter
I'm glad for that.
