shapefile examples
26587
07-07-2017 09:43 AM
DennisCooper
I am looking for some examples of shapefiles (DBF,SHP,SHX,SBN) for latest version.  I am having difficultly locating examples on the website.  Thanks.
MicahBabinski
Hi Dennis,
Do you mean the latest version of ArcGIS Desktop software? Or the latest version of the shapefile specification? If you just need some random example shapefiles try visiting your favorite Open Data Site. Here are two of mine:
Home | HIFLD Open Data
City of Portland Open Data Site
Micah
DennisCooper
Micah,
Thanks for those references.
Here is my situation. I have some software that reads a SHP file. I understand the spec has changed with regards to locations. In particular, I believe the level of precision in LAT, LON data has changed. Further, the change is with respect to this particular format (example for LAT): NDDMMSS.SSS
I have gone to the two web sites you referenced below and have been looking through the available data and so far all the data is in decimal degrees, which doesn’t help.
Thanks again,
…Dennis
DanPatterson_Retired
The shapefile technical description can be accessed here
http://support.esri.com/en/white-paper/279
and directly here
http://downloads.esri.com/support/whitepapers/mo_/shapefile.pdf
and it remains the same since 1998.
In any case, a shapefile whose coordinates are in geographic coordinates are recorded in decimal degrees and no other variant like degrees, minutes, seconds or degrees decimal minutes etc.
Coordinates in planar units are most likely in meters although feet are used for some projections in the U.S (and historically elsewhere).
