Mapping With Design Tutorial Error
487
6
08-05-2022 12:24 PM
JustinBurker
New Contributor II
Hello I am having trouble with the 4.2 tutorial in Mapping by Design. OSM points does not load. "Too much data to draw. Synced artwork may be unaffected."
Operating System: Windows 10 64-bit
Host Application: ILST 26.4.1
M4CC Version: 3.2.0
License Type: ArcGIS GISProfessionalAdvUT
ERROR: [osm_points - point] Too much data to draw, synced artwork may be unaffected.
Date: 8/5/2022 2:57:25 PM
Extent: xmin=1195470.3320811228 ymin=8376566.84726136 xmax=1198015.4462573729 ymax=8379469.0656791385 spatialReference=102100
MapScale: 4500
MapScale: 4500
SarahBell
Hi @JustinBurker . Could you please retry, and respond with how it goes? The map has been updated, and tested with success on the team's end. I look forward to hearing back from you to see if it works for you as well.
Sarah
JustinBurker
New Contributor II
This is when I am adding add content overwrite webmap.
SarahBell
Hi @JustinBurker . Thanks for posting this. I will have the team investigate. While I'm doing that, can you try to move forward with the tutorial anyway. The message you're getting might not impact the final map. I hope that's it!
SarahBell
Hello again, @JustinBurker . This issue has been logged with the dev team, and they are working on it. Stay tuned...
JustinBurker
New Contributor II
Thanks.
SarahBell
Sarah
JustinBurker
New Contributor II
It loaded thanks!
