Can not build project - OAuthAuthenticationChallengeHandler error
642
10-25-2023 02:47 AM
Thomas_Markussen
Hey, I am using the ArcGIS SDK for Unreal Engine, and I have no problems in the editor, but it throws an error with the OAuthAuthenticationChallengeHandler when I try to package the project.
I am probably doing something wrong, but wanted to know if anyone had experienced this same error.
This is the bulk part of the error in the output log:
PackagingResults: Error: appError called: Assertion failed: IsValid() [File:D:\build\++UE5\Sync\Engine\Source\Runtime\Core\Public\Templates\SharedPointer.h] [Line: 1071]
PackagingResults: Error: begin: stack for UAT
PackagingResults: Error: === Critical error: ===
PackagingResults: Error: Assertion failed: IsValid() [File:D:\build\++UE5\Sync\Engine\Source\Runtime\Core\Public\Templates\SharedPointer.h] [Line: 1071]
PackagingResults: Error: [Callstack] 0x00007fffbf2801f9 UnrealEditor-SlateCore.dll!UnknownFunction []
PackagingResults: Error: [Callstack] 0x00007fffbf41f0bc UnrealEditor-SlateCore.dll!UnknownFunction []
PackagingResults: Error: [Callstack] 0x00007fff907c2721 UnrealEditor-ArcGISMapsSDKEditor.dll!SharedPointerInternals::NewIntrusiveReferenceController<1,SWindow>() [H:\Epic Games\UE_5.1\Engine\Source\Runtime\Core\Public\Templates\SharedPointerInternals.h:445]
PackagingResults: Error: [Callstack] 0x00007fff9082ffa9 UnrealEditor-ArcGISMapsSDKEditor.dll!UArcGISEditorOAuthAuthenticationChallengeHandler::HandleChallengeInWebBrowser() [F:\Ramboll\UEProjects\ArcGISUnreal\Plugins\ArcGISMapsSDK\Source\ArcGISMapsSDKEditor\Private\Security\ArcGISEditorOAuthAuthenticationChallengeHandler.cpp:56]
PackagingResults: Error: [Callstack] 0x00007fff9082fced UnrealEditor-ArcGISMapsSDKEditor.dll!UArcGISEditorOAuthAuthenticationChallengeHandler::HandleChallenge() [F:\Ramboll\UEProjects\ArcGISUnreal\Plugins\ArcGISMapsSDK\Source\ArcGISMapsSDKEditor\Private\Security\ArcGISEditorOAuthAuthenticationChallengeHandler.cpp:148]
PackagingResults: Error: [Callstack] 0x00007fffa3806c64 UnrealEditor-ArcGISMapsSDK.dll!<lambda_e5258f30984c88f752c6d28bf71aba8e>::operator()() [F:\Ramboll\UEProjects\ArcGISUnreal\Plugins\ArcGISMapsSDK\Source\ArcGISMapsSDK\Private\Subsystem\ArcGISMapsSDKSubsystem.cpp:135]
  For context:
I just added the SampleOAuthAuthenticationChallengeHandler component to the Map Actor. I have my API key both in the project, and in the SDK menu. I am using the authentication configurations too with "urn:ietf:wg:oauth:2.0:oob", but I have some trouble logging in using the pop-up windows, so I don't really use it.
Any ideas?
PhucTran1
Same here. No one supports on this?
NhaNguyenDinh
I'm facing the same problem too. Please check for this error!
PhucTran1
Still no response on this?
