Hi Ross,
Esri does not provide the chart data. You can purchase this through Admiralty Maritime Data Solutions by finding a local distributor https://www.admiralty.co.uk/how-to-buy?title=&field_new_avcsonline_value%5B1%5D=1
There are vector as well as raster options but it typically comes down to the license agreement and what you are trying to do with the data.
Are you looking for vector data to load into a geodatabase for analysis? Or are you looking for raster data as a web service that you can use as a basemap?
Here's a public site from NOAA that displays S-57 ENC datasets as web services. You can search NOAA ENC Online in ArcGIS Pro's catalogue pane to load this MapServer into your project as an example. This service uses the ArcGIS Maritime Server Extension.
The ArcGIS Maritime Server Extension can also load the UKHO AVCS S-63 datasets if you require hosting them yourself.
Looking forward to your reply.
Tom
