Good afternoon all:
I am running into a glitch of sorts with displaying S-57 ENC charts in ArcMap, but first a bit of background. While I am experienced in ArcGIS, I have only recently begun using the Maritime Charting/Bathy extensions. That said, I had no trouble setting up my Nautical environment. Before deciding to post the following question, I have researched as much ESRI Help material online as I was able to find (including all the Charting/Bathy tutorial videos from Mrinmayee Bharadwaj and Bertrand Baud), and have been unable to find a solution.
1. When I load a chart on my Maritime-enabled machine, the display looks like this (1:40,000, all layers except M_QUAL_A enabled):
However, when I load the same chart on another machine that only has the ESRI S-57 Viewer installed, it looks more like what I would expect, (also 1:40,000 with all layers except M_QUAL_A enabled):
I suspect this is a simple fix, but I am unsure how to proceed; I could use a shove in the right direction. I am running ArcGIS 10.7.0.1045, with the full Maritime Charting and Bathy extensions enabled. I imported these charts using the 'Import S-57 to Geodatabase' tool, and displaying the NAUTICAL featureset. My NIS is a FGDB using the the NAUTICAL_ENC_TEMPLATE_VXXXXXXXX_GX.XML for its schema.
2. The S-57 Viewer allows me to explicitly choose which charts to load and display, (see second image above). However, I see no such control when using the charting extension. I can load charts into the NIS with the 'Import S-57...' tool, but I see no way to choose which charts to actually display on the map.
Thank you for your time.
--Nate Murry
