Hi all,
I thought I'd add to this post as I had a similar Token error that was very difficult to diagnose.
Essentially when I tried to establish a connection I got the following error:
Token Error
Failed : Server Input Error - cannot find server xxxxxxx:443
For me this issue was nothing to do with the way I tried to install ArcGIS Monitor but a missing DLL on our server.
I needed help from one of our Senior Systems Engineers to find the cause of this issue.
When we tried to run the following from the command prompt:
mongod --storageEngine wiredTiger --dbpath E:\ArcGIS_Monitor\Mongo\Data --port 27017
MongoDB failed to start and reported that there was a missing DLL.
When we investigated this DLL it turned out we need to update our MS C++ Redistributable to the 2019 version on the Server
Once we update the MS C++ Redistributable and restarted the server then re ran the Post Installer and checked the logs
MongoDB was ok and we were able to create a connection
Hopefully this helps someone else and saves them a world of pain.
Clinton
