Hi - I am trying to create a simple (I think) custom notification in ArcGIS Monitor. I want to be notified when a Service Status is 'stopped'. I have tried several variations but this field (and others) do not populate. When I try to enter a value manually, it disappears when I click save. Some of the drop downs do work - like selection the Internal Address. See my attached image for details. We are using ArcGIS Monitor 2023.2.0 and ArcGIS Server 10.9.1
Am I missing something or can you only get notifications based on the few Metrics. Was hoping to find 'out of the box' functionality to let me know via email when a service is stopped.
Thank you!
Hi Josh -
I summited to Esri and turns out it was a bug that they were able to reproduce the issue and is filed under: BUG-000161901.
Plan to update this post when fix is available.
I will update
Hi Patrick,
Are you still facing this issue? If so, can you please reach out to Esri Support to troubleshoot this further?
Josh
Hi Josh -
I will update
