I'm trying to create a route using Network Analyst. Just at the beginning stages of setting this up for a school project.
I have a feature class called RoadsClipped, and successfully set up a Network Dataset called Roads_ND using it.
Now I'm trying to customize the routing cost using evaluators. I want to use attributes in RoadsClipped, but anything I've tried to access those attributes results in a "Network element evaluator error". I've tried both VBScript and Python.
Some simple examples are below. I've tried literally hundreds of variations and nothing work unless I forego trying to look at the attribute entirely. These are just simple tests to see if I can get at the attributes in RoadsClipped, and not the real logic I'll eventually use.
Python:
def SetCost(value):
a=Edge.AttributeValueByName(value)
c=0
if l!=0:
c=100/a
return c
value=SetCost("SPEED_LIM")
VBScript:
a=0
a=Edge.AttributeValueByName("SPEED_LIM")
value = a
Any suggestions?
