Network construction
1575
11
10-23-2019 07:04 AM
DavidCuberes
New Contributor II
When I try to create a network dataset from a SHAPEFILE I get the error: "could not create network dataset". I am following all the steps although most of what I found refer to using a GEODATABASE instead of a shapefile, so perhaps this is the problem. Can anyone help??
Thanks
David
Tags (1)
JaySandhu
Elevations are not necessary to create a network dataset.
The most basic way to create a network dataset in Catalog is to right-click on the lines shapefile and choose New Network Dataset. Then Next through the wizard taking all defaults and then click Finish. That should create a network dataset.
Can you also check if there is an existing network dataset based on the same lines shapefile in that folder? A shapefile can only participate in one network dataset at a time.
Jay Sandhu
RobertBorchert
Frequent Contributor III
To create a network dataset you have to be in a file geodatabase
To create a Geometric Network you need to be in a file geodatabase or a personal geodatabase.
KoryKramer
Esri Community Moderator
Robert - that isn't true.  Creating a network dataset—Help | ArcGIS Desktop
Network datasets can be created from shapefiles.  This may require some troubleshooting.
David, is that the only error?  "could not create network dataset"
What is the path of the Windows folder where the shapefile sits?  Can you check the security/permissions of that folder - do you have write access?
DavidCuberes
New Contributor II
I don't see any other error. The path is "D:\Dropbox\growth_shadow\cross_sections\RAILROADS\RR1826-1911Modified050916.shp". I am not sure what you mean... Do I need a permission yto access my Dropboox from ArcCatalog or ArcDesktop...
In another message I mentioned that I don't have elevation measures. Shall I try to create them? Also... these are railroads and I would like to map them on a county map. So I do have a county shapefile besides the railroads shapefiles. Perhaps the thing is that they should be both in a folder?
thanks again
DavidCuberes
New Contributor II
Kory, what do you mean by "Network datasets can be created from shapefiles.  This may require some troubleshooting." What kind of troubleshooting? I think this may be the problem I am facing...
thanks
JaySandhu
Do you have write permission to the folder where you are creating the network dataset?
Jay Sandhu
DavidCuberes
New Contributor II
Jay,
Yes, it is my Dropbox account.
JaySandhu
Just to rule out the issue of a dropbox, can you copy the shapefile to a new folder on your local disk drive and try again?
Also, what version of the software are you using?
Jay Sandhu
DavidCuberes
New Contributor II
I will try that, thanks. I am using version 10.5.
DavidCuberes
New Contributor II
I did that but still no success. Do you think the fact that my data does not have elevation may be causing this? Can you point me to some online tutorial where a SHAPEFILE is transformed into a NETWORK DATASET?
thanks
