Thank you Jeremiah. You explained it very well. I'm able to do everything quite easily using model builder. I've built a dataset and it works for the most part, there are some funny routes but I think this is down to the data quality. I also made a dataset without doing it in 3D, just offset the routes, and it seems to work the same. Can I ask you to put up screenshots of your Time evaluators? I followed the tutorial but I get errors when I try and route using my evaluator for time
