Hi there,
I am trying to map out routes in NYC using GTFS Public Transportation Data. I used the ArcGIS Pro Tutorial to create the Network Dataset, but when I am creating route layers, they do not seem to be following the available public transportation routes. I have attached a screenshot- the colored lines are the results of GTFS Shapes to Features from all the GTFS layers I used to build the network dataset (buses, subways, and ferries), and the purple line is the route between points 1 and 2 (created using create route layer, add locations, and solve- screenshot attached of the settings). It does not appear to be following any available public transit routes. I'm not sure if this is an issue with how I set up the Network Dataset, or if it is an issue with how I am running the Route tool. I also wonder if there is an issue with how the Network deals with travelers walking under the expressway overpass (the darker green line directly to the right of stop #1) in order to reach the major subway lines that are on the other side of the overpass (red/orange/yellow lines to the right) which is a commonly used route in reality, and if there would be any way to resolve that.
Thanks in advance for any advice!
