Hi, I'm trying to process a Navteq Navstreets native 2014.3 dataset (BB_Q314 - Belgium), but after 57 steps i have the following error:
Calculating the distance, speed, and language fields... Value does not fall within the expected range. at ESRI.ArcGIS.Geometry.IPolycurveGeodetic.get_LengthGeodetic(esriGeodeticType geodeticLineType, ILinearUnit pLU) at GPProcessVendorDataFunctions.ProcessNavStreetsDataFunction.CalculateMetersKPHAndLanguageFields(String outputFileGdbPath) at GPProcessVendorDataFunctions.ProcessNavStreetsDataFunction.Execute(IArray paramvalues, ITrackCancel trackcancel, IGPEnvironmentManager envMgr, IGPMessages messages) Failed to execute (ProcessNavStreetsData). Failed at ...
I've tried it with several ArcGis for Desktop versions (10.1, 10.2, 10.2.1, 10.2.2), with a smaller dataset, with different specifications in the tool (gdb 10, gdb 10.1, metric), background geoprocessing is disabled, ... . My work folder is c:\navteq. Does anybody has the same error and/or a solution for this? Very frustrating...
