I'm trying to create a couple of live data feeds with Python. I would normally build them with arcpy and Windows scheduled tasks, but IT permissions issues are putting up roadblocks. It looks like AGOL Notebooks might suit my needs, and I will probably run an ArcPy kernel (we have credits). I have some specific questions, but any tips or tricks moving to the AGOL Notebook environment are appreciated.
If you're using arcpy to do processing, how do you publish to AGOL? In Pro, I would have a local feature class in an APRX map layer, which I use to create a service definition draft and service definition. My symbology and metadata all tag along for the ride. In AGOL notebooks, I'm envisioning my feature classes and rasters will be variables, such as the output from a geoprocessing task, but then what's the preferred way to publish that to AGOL?
Where do you store temp data? I uploaded a mostly empty zipped FGDB to my notebook's files and unzipped it. I can read and write there, so I guess that works, but I'm not sure this is the best way to use this tool. No specific question here, just wondering about general strategies for temp data storage. Do you tend to use more in-memory feature classes and rasters in this environment? Or do you publish temp data to AGOL and then consume it?
How about development workflow? Do you develop in a local IDE (e.g.: Visual Studio Code, Spyder, PyCharm) or Pro Notebook and push that out to your AGOL Notebook? Or do you just develop in AGOL? I think I would go crazy without a debugger...
How about source code management in Git? I see AGOL Notebooks have snapshots, but wondering if anyone has tips for checking code into Git.
I could keep going, but any strategies, things you struggled with, or clever hacks are appreciated. My brain is on overload thinking about moving from IDE-based arcpy code to the AGOL Notebook environment.
thanks!
