I've noticed over the last few days that the schedule seems to be getting stuck, today the 4am task started to run but then every task after it is showing as skipped and that the 4am task is still running.
"result": {
"messages": [
"Run id 'd134a....c' of task id '637....e' was skipped because a previous task run was still in an executing state."
@Anonymous User is it having issues again?
the task usually takes a few minutes to run and i have checked my code and cant see any reason why it would still be running
i guess a work around for me would be to update my code to check how long its been running for and if its over x minutes get it to stop but it might be good if there was a timeout option when you actually scheduled a task
