How to export a GPX file from ArcGIS online?
7484
01-29-2015 03:28 PM
Recently, I create my map by using ArcGIS online. I draw some tracks on my map layer. I want to export the track layer to a GPX file so that I can put the GPX file into my GARMIN device. But, it is not successful with trying many times. Please tell me how to export a GPX file from ArcGIS online. Thank you very much.
Comments
MarcGalle
New Contributor II
Easiest way is to export AOL to shapefile then use DNRGPS to send back to GPX
delicadiesel
Thank you for your response. I try many times with your method and other ones. But, I failed every time. What I want to do is drawing a track on any kind of the map layer online with using a public computer. When I go home after, I can export the online track data to a GPX file. Then,I can import the GPX file to GARMIN basecamp to view and edit. Can ArcGIS online do that? If it can, please tell me how to do? Thank you very much again.
AkosKisreti1
There is no way to create GPX file in ArcGIS Online. You can only export to shapefile, File GDB, CSV or KML.
Akos
Version history
Last update:
‎01-29-2015 03:28 PM
Updated by:
Contributors
