AGOL Zoom to visibility scale
709
05-13-2015 06:34 AM
Status: Open
ChristopherThompson
Occasional Contributor III
Please add a Zoom to Make Visible option for layers in webmaps.  This feature is available within ArcMap and seems like it would be very helpful in web maps when visibility scales are set.
2 Comments
AnninaHirschi_Wyss1
You could use the "zoom to" in the layer properties, but this zooms into the center of the respective layer wich is not necessarily the same as defined Map Extent. The Map Extent and not the Layer Extent should be taken as reference to zoom in.
AnninaHirschi_Wyss1
And this option should also be available in the Layer List Widget Configuration of Web AppBuilder
