import/export filter in AGOL map feature, many times our filters are duplicated in multiple layers and maps sometimes with one thing different, it would be nice if we could cut out time rebuilding them by being able to - import them from file, import them from another layer and export them to file. I know copy layer is an option to copy filters but if you have to change one significantly you have to change the rest manually or make a new copy at which point if you have custom styles in each you have to do that again. and then updating other maps that also need the same filters is manual.
it would be great to be able to do the same thing with styles
