I just came to the ideas forum to post something like this! Would be great to import a layer file to set symbology etc, and would save so much time when creating view layers.
Stunning omission from AGOL functionality IMO. Iterating and updating layers in longer term projects is made sooooo much more tedious by needing to apply customized symbols manually every time a layer in a web map is replaced with an updated version.
I also second this functionality. It's a bit backwards to be able to edit hosted features directly in Pro, but not have the ability to change its symbology.
Agree with all of the above. If I'm making a map in Arc Online, it's because I wanted to make a map in Arc Online - not because I wanted to go back and forth between Online and Pro. Stunning omission indeed.
Yes Please. I primarily work in cross-organizational collaboration, and when receiving data from a collaborator to host It would be BEST if I could leverage the data owner's preferred symbology.
I support the request of the OP, if its possible to program in AGOL.
Use Case: Pulling hosted features off AGOL for modification of domains / subtypes / fields etc.. in ArcPro then rehosting as a new HFL.
Desired workflow: existing HFL in AGOL could be used to symbolize the newly hosted / updated HFL in AGOL. Ideally this option would be on the visualization tab and also available in the new Map Viewer.
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
var labelSname = "";
if(labelEle[i].querySelector("ul li:nth-child(1)").getAttribute("aria-hidden")){
labelSname = labelEle[i].querySelector("ul li:nth-child(1)").outerHTML;
labelEle[i].innerHTML = "";
labelEle[i].innerHTML = labelSname + trLabelsHtml;
catch(e){
/* V 2.0:3 = Store not translated reply id */
if(lingoRSXML.snapshotLength == 0){
if($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
var lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for(var i=0;i 0) {
var attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('div.custom-attachments');
if (attachDiv) {
attachDiv = attachDiv.outerHTML;
else if(rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('#attachments').length > 0){
if ("IdeaPage" == "BlogArticlePage") {
attachDiv = rootElement.querySelector('div.lia-quilt-row-main .lia-message-body-content').querySelector('#attachments');
if (attachDiv) {
else{
attachDiv = "";
}else{
attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('#attachments').outerHTML;
else {
attachDiv = "";
/* Feedback Div */
var feedbackDiv = "";
var feedbackDivs = rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('div.lia-panel-feedback-banner-safe');
if (feedbackDivs.length > 0) {
for (var k = 0; k < feedbackDivs.length; k++) {
feedbackDiv = feedbackDiv + feedbackDivs[k].outerHTML;
else {
var attachDiv = rootElement.querySelector('div.lia-message-body-content').querySelector('div.Attachments.preview-attachments');
if (attachDiv) {
} else {
attachDiv = "";
/* Everyone tags links */
if (document.querySelectorAll("div.TagList").length > 0){
var everyoneTagslink = document.querySelector('div.lia-quilt-row-main').querySelector(".MessageTagsTaplet .TagList");
if ((everyoneTagslink != null)||(everyoneTagslink != undefined)){
everyoneTagslink = everyoneTagslink.outerHTML;
else{
everyoneTagslink = "";
/* Feedback Div */
var feedbackDivs = rootElement.querySelector('div.lia-message-body-content').querySelectorAll('div.lia-panel-feedback-banner-safe');
for (var m = 0; m < feedbackDivs.length; m++) {
feedbackDiv = feedbackDiv + feedbackDivs[m].outerHTML;
} catch (e) {
if (body_L == "") {
/* V 2.0:7 Replacing translated video data with source video data */
var newBodyVideoData = newBody.querySelectorAll('div[class*="video-embed"]');
angular.forEach($scope.videoData[value], function (sourceVideoElement, index) {
if (index <= (newBodyVideoData.length - 1)) {
newBodyVideoData[index].outerHTML = sourceVideoElement.outerHTML
/* V 2.0:7 = Replacing translated image data with source data */
var newBodyImageData = newBody.querySelectorAll('[class*="lia-image"]');
angular.forEach($scope.imageData[value], function (sourceImgElement, index) {
if (index <= (newBodyImageData.length - 1)) {
newBodyImageData[index].outerHTML = sourceImgElement.outerHTML;
/* V 2.0:7 = Replacing translated pre tag data with source data */
var newBodyPreTagData = newBody.querySelectorAll('pre');
angular.forEach($scope.preTagData[value], function (sourcePreTagElement, index) {
if (index <= (newBodyPreTagData.length - 1)) {
newBodyPreTagData[index].outerHTML = sourcePreTagElement.outerHTML;
var copyBodySubject = false;
if (body_L == "") {
copyBodySubject = true;
body_L = newBody.innerHTML;
/* This code is written as part of video fix by iTalent */
/* try{
var iframeHTMLText = body_L;
var searchIframeText = "<IFRAME";
var foundiFrameTag;
if (iframeHTMLText.indexOf(searchIframeText) > -1) {
foundiFrameTag = decodeHTMLEntities(iframeHTMLText);
foundiFrameTag = foundiFrameTag.split('src="')[1];
body_L = foundiFrameTag;
catch(e){
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
body_L = body_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
/** We should not replace the source content if user profile language and selected target language matches with source language **/
if(showTrContent) {
var compiled = false;
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = null
if("IdeaPage"=="IdeaPage"){
// var customAttachDiv = '';
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv ;
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
compiled = true;
/* Attach atttach div */
// document.querySelector("div.translation-attachments-"+value).innerHTML = attachDiv;
rootElement.querySelectorAll('div.lia-message-body-content')[0].insertAdjacentHTML('afterend',attachDiv);
if(rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message').length > 1){
rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message')[1].remove();
} else {
if("IdeaPage"=="TkbArticlePage"){
}else{
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv + attachDiv;
compiled = true;
/* Destroy and recreate OOyala player videos to restore the videos in target languages which is written by iTalent as part of iTrack LILICON-79 */ /* Destroy and recreate OOyala player videos */
try{
// $scope.videoData[value][0].querySelector("div").getAttribute("id");
for(var vidIndex=0; vidIndex<$scope.videoData[value].length; vidIndex++){
if( $scope.videoData[value][vidIndex].querySelector("div") != null){
var containerId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].containerId;
videoId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].videoId;
/** Get the Video object */
vid = OO.Player.create(containerId,videoId);
/** Destroy the video **/
vid.destroy();
/** recreate in the same position */
var vid = OO.Player.create(containerId,videoId);
catch(e){
try{
for(var vidIndex=0; vidIndex<($scope.videoData[value].length); vidIndex++){
if($scope.videoData[value][vidIndex].querySelector('video-js') != null){
var data_id = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-video-id');
var data_account = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-account');
var data_palyer = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-player');
var div = document.createElement('div');
div.id = "brightcove";
div.class = "brightcove-player";
div.innerHTML =
'(view in my videos)'
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
if(!compiled){
/* Re compile html */
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/langTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector('.lia-quilt-occasion-message')){
rootElement.querySelector('.lia-quilt-occasion-message').appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
/* V 1.1:2 = Reply Sync button for multi source translation */
} catch(e){
console.log(e);
if((rContent != undefined) && (rContent != "")) {
drawCanvas(decodeURIComponent(rContent));
/** Update variable with selected language code **/
$scope.previousSelCode = code_l;
* @function manageTranslation
* @description Managess the translation of given language for the thread
* @param {string} langCode - Language Code
* @param {string} tid - Thread ID
$scope.manageTranslation = function (langCode, tid) {
//debugger;
$scope.showTrText = false;
/* V 2.0:5 = actualStatus variable introduced to indicate detailed connector status on UI. This variable holds the actual translation percentage */
$scope.transPercent = "";
$scope.actualStatus = "";
if (tid != "") {
var bulkTranslation = lithiumPlugin.bulkTranslation(langCode, tid);
bulkTranslation.then(function (trContent) {
if(trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, langCode);
if(langCode != "en-US") {
$scope.showTrText = true;
if((trContent.status != "NA") && trContent.status != null) {
// $scope.transPercent = String(trContent.status);
$scope.actualStatus = String(trContent.status);
} else {
// $rootScope.errorMsg = "Translation is in progress. Please check again a few minutes."
$rootScope.errorMsg = "Translation is in progress. Please retry in a few minutes."
$scope.workbench = trContent.wb;
/* V 2.0:4 = Trigger uncalled or delayed callbacks (documnet uploaded/translation completed from lithium).*/
if(trContent.callback == 'true') {
var trCompletCallback = lithiumPlugin.trCompletCallback(langCode, trContent.docID);
trCompletCallback.then(function (callback){
// $rootScope.errorMsg = "Downloading Translated content in " + langCode + " now. Please check again in a few minutes."
$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if (trContent.callback == 'upload') {
var trCompletUpload = lithiumPlugin.trCompletUpload(langCode, trContent.docID);
trCompletUpload.then(function (callback) {
//$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if ("many" == "one") {
$scope.updateOOS();
} else if("SmartConx" == "SmartConx"){
if ("many" == "many"){
$scope.updateOOS();
}else if ((trContent.status != null) && trContent.status.includes("100")) {
/* If everything fine then only check Out of Sync status */
$scope.updateOOS();
} else {
/* If translation perccent is less than 100 then show the percentage on UI */
$scope.transPercent = $scope.actualStatus;
* @function selectThisLang
* @description Called on select dropdown.
* @param {string} lang - Language code
$scope.selectThisLang = function (lang, anonymousFlag) {
/* 1.4:3 Update Analytics on language selection */
try {
lingoThreadLangSelected(lang, '941280');
} catch (e) {
/** Display Translated content **/
var getTranslation = lithiumPlugin.getTranslation(lang, "941280");
getTranslation.then(function (trContent) {
if (trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, lang);
} else {
//$rootScope.errorMsg = "Translation is in progress. Please check again in a few minutes."
var decodeEntities = (function() {
// this prevents any overhead from creating the object each time
var element = document.createElement('div');
function decodeHTMLEntities (str) {
if(str && typeof str === 'string') {
// strip script/html tags
str = str.replace(/
