Thank you James. That works great and it's good to know the other EXIF tags that can be pulled as well.
The project I have setup also incorporates photo attachments using Collector. Is there a way to access tags (and populate them into a field) for photos taken in Collector?
To briefly explain, I have designed a project for our parking enforcement officer to use while monitoring timed parking spaces. The parking space point feature class utilizes a custom URL to launch Survey123 from Collector when a parked car is initially inventoried. The point feature class generated by the submitted surveys is then displayed back on a map in Collector and when a vehicle has been parked for more than the posted limit the symbology changes from green to red. The parking enforcement officer then opens the point in Collector and adds an additional photo when issuing a citation. To this point I have just been using simple dateTime fields to capture when the vehicle was initially inventoried (when Survey123 is launched) and then again when the officer opens the point in Collector when issuing a citation.
Thank you for any suggestions you may be able to provide.
