Add JSON or geoJSON Layer to ArcGIS Online Map from CartoDB REST Endpoint?
7420
11-05-2014 12:55 PM
ThomasSkowronski
New Contributor II
Is it possible to use a CartoDB REST endpoint that emits JSON or geoJSON as a layer in my ArcGIS Online map?
It thought there would be something like Add Layer From Web - geoJSON
Thank you -- Tom
papegowda1
Hi Tom,
did you find the way for it.
thanks
pape gowda
BrianFlood
you can use esri's koop as an intermediary service for geojson
Esri/koop · GitHub
AdamJoseph1
If you can extend koop to do this job or as an alternative export your data to cartoview and
serve ArcGIS Server REST compatible services from cartoview
ThomasColson
MVP Frequent Contributor
You can, in theory, do this by building a CartDB SQL Query which outputs KML, such as https://nps.cartodb.com/api/v2/sql?filename=NPS_Roads&format=kml&q=SELECT+*+FROM+roads%20where%20uni...
and then adding a kml link. Similar to adding a network link to Google Earth
