Larry,
Can you provide the URL to the logo you are using?
Which template are you using?
Can you share your application's URL here?
Mike
Larry,
Mike
I guess I don't quite understand. I took the URL you included and put it over the map. The logo is sized exactly the same as the original and looks the same as well, fuzzy and all. See the attached; you can see the configuration button sizes for comparison.
The template will display whatever size image you provide. I'm not seeing a huge image.
Mike
