Has anyone encountered an issue with a popup window showing a long number for the date field? This just happened the other day and we've never had this issue and I can't figure out what's causing it. Map Viewer is showing the date field properly, but on our actual GIS website it shows as if it's a coordinate number. Please see attached pictures.
This is from Map Viewer showing the popup window showing correct date format.
This is from actual GIS website showing same popup, but with date field format incorrect:
As I said, we've never had this issue until a few days ago and can't figure out where it's coming from. Everything in attribute table is showing the date fields with correct format. The date field is formatted as date and not string.
