AGOL popup appending portal URL onto hyperlinks
1195
03-20-2019 10:05 AM
Kara_Shindle
I just ran into this issue, and I was wondering if this was a organization security setting.
I am working in two AGOL accounts.  One is my own that I administer, and I have no problems with the pop up URLs, they work as they should (i.e. I create a custom popup and specify an attribute as my website link, & voila! popup has a nice link to an outside URL that works fabulously).
The second AGOL account is for an organization and I am a user who can create web maps.  But creating a popup with a custom website URL results in it appending the organizations portal URL to the beginning of whatever website I have in my attributes.
i.e. "www.google.com" in the attributes becomes "<organization>.maps.arcgis.com/home/webmap/www.google.com"
My only guess is that it is a security setting...
Since I do not administer the second account, they are asking what setting they need to fix in order for the popup URLS to work properly.
Anyone have any ideas?
RobertScheitlin__GISP
What does the exact value of your link look like? Are you just using "www.google.com" (for example) and not adding the http or https?
Kara_Shindle
I am just using www.google.com for an example.  I received this data and it appears that all of the web addresses start with www.
Kara_Shindle
Your question got me looking at the web addresses, and creating an arcade expression to concatenate the http / https onto the addresses fixed my issue.  Thanks for the boost!
KellyGerrow
Esri Frequent Contributor
Can you share your web map?
