ArcGIS.com Viewer
824
05-09-2012 04:46 AM
KeisukeNozaki
Occasional Contributor II
If there are more than two editable layers in ArcGIS.com Viewer, how do users know which layer they are editing?
To switch editable layer, do users have to able or disable editing from Table of Contents every time?
MikeMinami
Esri Notable Contributor
They are all editable at once.
Mike
MikeMinami
Mike
KeisukeNozaki
OK, but how do users know which layer they are editing?
It does not show target layer like Desktop.
Mike
JoeFlannery
Occasional Contributor III
Keisuke:
If you set up a "Template" in the source map document, you will see a list during online editing.  See attached picture showing one featureclass with four line types in the template defined by an attribute field.
MikeMinami
You simply click on the feature you want to edit.
Try for yourself.
http://www.arcgis.com/home/webmap/viewer.html?services=d9aae60f3d5d41ca93f51d8a07998d05
Mike
