Hey @rachelm & @AlessioDiLorenzo ,
Alessio -
So it seems there are a few things going on so let me dive in a little. For the first question about Multidimensional data. When you are creating your multidimensional data, are you following the instructions to make it multidimensional here?
The rough steps are :
- Create a Mosaic Dataset
- Add the input images to MD
- Create MD fields to populate in MD
- Run Build Multidimensional Info tool.
This will create the .crf raster ready for your next steps. If created successfully, then you should see the Multidimensional options in ArcGIS Pro when you add it to a map.
That .crf can be added as an imagery layer in ArcGIS Image for ArcGIS Online.
Rachel-
For the Build Multidimensional Transpose tool to work, the required input is a multidimensional input image. It sounds as if the data being input is not multidimensional. The error posted indicates that the .crf is required because that format supports being multidimensional. If you follow the same steps indicated above to create the multidimensional crf before, then your process should work as well.
Let me know if either of you have any follow up questions.
Thanks
