ArcGIS Online Layers Freeze ArcGIS Desktop
1860
08-13-2013 10:30 AM
MatthewFoster
I'm wondering if anyone else has this issue and if there is something I can do to resolve it.  In the past I have used the slick ESRI base maps for many maps without an issue - good, relatively speedy performance when using them in ArcGIS desktop.  Recently they have gotten so slow as to be completely unusable to me.  I have tried using them in different networks (home, work, university) and all have the same performance issues for me.  When I add the baselayer (even the simple grey basemap) my cursor just spins until i decide to end the Arcmap process via Task Manager.  Interestingly, when using AGOL only, I can create a webmap with any of the basemaps and the performance is super speedy.  Thoughts?
Thanks much in advance!
Best,
Matt
MikeMinami
Esri Notable Contributor
We are not aware of any issues. Could something have changed with your network? I would check with your network people to make sure nothing changed. When you say you connect from various places, so you are running ArcGIS Desktop in a standalone fashion, without being connected to a work network?  If you still have issues, you can contact Esri Technical Support to further investigate the problem.
Mike
