arcgis online using sessionStorage getID
591
09-06-2016 09:09 AM
BrendanDuffy
New Contributor II
I have successfully launched an application from IIS However the session isn't working the same way as it was in the javascript widget.
Here is the break down from original javascript widget:
1. Form.html {this is the html page that houses the unique id that is being shared through a session to the JavaScript in the editor widget}:
var sample = "{{data}}";
sessionStorage.setItem("sample", sample);
2. JavaScript widget:
var sample1 = sessionStorage.getItem("sample")
  • var query = new Query();
  • qyery.where = "Unique_ID'" +sample1 +"'";
  • query.outFields = ["*"];
  • query.returnGeometry =true;
This successfully grabs the records based on the unique id provided in the form.html
Web app builder:
1. index html:<between script tags>
2. config.JSON
included Unique_ID = 'sample1'
This is being referenced 6 times
This doesn't not grab the sessionStorage.
Can you help me?
Thanks in advance,
Brendan
