I have been sending google sheets to AGOL maps using this method, and it works great for adding csv web layers to map.
The problem is that you have to add it via this method for each new map and set the same symbology every time.
Is there a way to create a layer in AGOL that references a web csv, so that the symbology could be saved, and the layer could be used in multiple AGOL maps without having to set symbology every time?
Will
