Here is some code that will allow you to add the editor toolbar to the basic viewer. We are going to make this a configurable option in the future.Here's what you have to do. In layout.css add the following: .esriDrawingToolbar{ position:absolute; top:0px; right:0px; left:0px; border:none !important; margin-bottom:40px; }
Then in layout.js replace the existing createEditor function with this one: function createEditor() { if (editorWidget) { return; } if (editLayers.length > 0) { var editLayerInfo = editLayers; var templateLayers = dojo.map(editLayers, function (layer) { return layer.featureLayer; }); //add field infos if applicable - this will contain hints if defined in the popup. Also added logic to hide fields that have visible = false. The popup takes //care of this for the info window but not for the edit window. dojo.forEach(editLayerInfo, function (layer) { if (layer.featureLayer && layer.featureLayer.infoTemplate && layer.featureLayer.infoTemplate.info && layer.featureLayer.infoTemplate.info.fieldInfos) { //only display visible fields var fields = layer.featureLayer.infoTemplate.info.fieldInfos; var fieldInfos = []; dojo.forEach(fields, function (field) { if (field.visible) { fieldInfos.push(field); } }); layer.fieldInfos = fieldInfos; } }); var editPanelHeight = dojo.style(dojo.byId("leftPane"), "height"); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, showTooltip: false, rows: "auto", columns: "auto", style: "height:" + editPanelHeight + "px;width:" + (parseInt(configOptions.leftpanewidth) - 10) + "px;" }, dojo.create("div",{},"editPanel")); templatePicker.startup(); var params = { map: map, templatePicker:templatePicker, layerInfos: editLayerInfo, toolbarVisible: true }; editorWidget = new esri.dijit.editing.Editor({settings: params}, dojo.create("div",{ id:"editDiv" },"editPanel" )); editorWidget.startup(); disablePopups(); } }
