I have an SDE geodatabase registered with ArcGIS Server. I'm attempting to create a new feature class for our tech to do some field data collection. I've created the feature class in the geodatabase, it works properly, I can edit in ArcMap. I've created a map service, and enabled feature access to allow for editing via the map service (Through the ArcGIS for iOS app, or Collector in the field). When I bring the service layers into an ArcGIS Online map, editing is not enabled. I pull in other services that I have previously been able to edit via an Online map, the editing works fine for those layers, but not the new one. It's just this one particular, newly created feature class.
Like I've said, I have registered the geodatabase with ArcGIS Server. Feature access is enabled. I've registered the feature dataset as versioned. I cannot figure out what step I'm missing.
It only seems to work with services/feature classes that I've previously been able to edit. Trying to create new services/feature classes doesn't seem to be responsive.
Anyone else run into this, or know what step I'm missing? At this point, I'm out of ideas.
