Embed an ArcGIS map with content menu
629
09-02-2019 02:40 PM
RickThomas
New Contributor III
I am trying to embed a map in a web site as I have in the past and the contents are no longer available.  I can get the details and legend without problem, but no contents. What happened?
The page I am working with is here:
https://www.intimeandplace.org/Immigration/Irish/Maps/irelandmap.html
Thanks for any help
InaAhern
New Contributor III
Hi Rick-
I just tested, and was able to do get a contents layer I could toggle on and off by clicking the box for Layer Toggle that appeared under the Legend when I turned the Legend option on.  See Screen grabs:
Is that what you're looking for?
RickThomas
New Contributor III
Thanks, Ina -
Only partly what I want. All of my materials are built around having the Content tools there to use - the Change Style, Filter, etc. And I can’t seem to get these to show in the embedded map.
Thanks again,
Rick
InaAhern
New Contributor III
Hmmm....I see what you mean.  If it helps any, when I opened the map you had linked, I was provided with an option to "Open Map in Full Screen" at the bottom of the page which then did open it in the real map viewer so I could manipulate those things.  Certainly not an ideal approach....
