Error message for publishing service on ArcGis online
587
03-29-2017 10:09 AM
SharmisthaBanerjee
I am trying to publish a mosaic dataset that has three overlayed raster files. I need this mosaic dataset to run suitability model in ArcGIS online suit Geoplanner.  While I am trying to publish the mosaic dataset as service from Arc Map, I am getting an error message that says "Layer's data source is not supported".  How do I solve that problem? Please help.
KellyGerrow
Esri Frequent Contributor
Hi Sharmistha Banerjee‌,
Mosaic datasets are not supported data sources for publishing hosted feature services. If you are looking to view the imagery, consider publishing a hosted tile service
You can also look into publishing a Mosaic Dataset to ArcGIS Server: How To: Publish a mosaic dataset to ArcGIS Server
-Kelly
KellyGerrow
-Kelly
