Also v. 56.x. I've cleaned browser cache with no luck. Run Dev Tools but will now have to read what it means. Got a return showing code with red lines through it. I'll try fiddler2 and compare not loading to successful load with Incognito. I'll also put a clean install of Chrome on a VM machine to see if that makes a difference.
Not sure what I'm doing, but Dev Tools shows it hanging at line 64 with these warnings:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
p.getText @ init.js:14
pa @ init.js:32
a @ init.js:10
(anonymous) @ init.js:19
ga @ init.js:28
ma @ init.js:19
La @ init.js:20
p @ init.js:10
(anonymous) @ index.html?appid=d620139…:81
init.js:36 Error: multipleDefine
at d (init.js:10)
at Ja (init.js:32)
at init.js:33
at a (init.js:10)
at Xa (init.js:33)
at s (init.js:30)
at HTMLScriptElement.<anonymous> (init.js:35)
(anonymous) @ init.js:36
(anonymous) @ init.js:14
a @ init.js:10
p.signal @ init.js:14
Ja @ init.js:32
(anonymous) @ init.js:33
a @ init.js:10
Xa @ init.js:33
s @ init.js:30
(anonymous) @ init.js:35
init.js:37 src: dojoLoader
init.js:37 info: Object {pid: "esri", mid: "esri/layers/LabelLayer", pack: Object, url: "http://js.arcgis.com/3.19/esri/layers/LabelLayer.js", executed: 0…}
init.js:37 .
at d (init.js:10)
at Ja (init.js:32)
at init.js:33
at a (init.js:10)
at Xa (init.js:33)
at s (init.js:30)
a @ init.js:10
Ja @ init.js:32
a @ init.js:10
Xa @ init.js:33
s @ init.js:30
init.js:37 .
init.js:2223 Uncaught TypeError: d is not a constructor
at init.js:2223
at fa (init.js:28)
at init.js:28
at ga (init.js:28)
at da (init.js:28)
at s (init.js:30)
(anonymous) @ init.js:2223
fa @ init.js:28
(anonymous) @ init.js:28
ga @ init.js:28
da @ init.js:28
s @ init.js:30
If anyone sees the origin of the glitch, I'd appreciate a note (or any other information that might be helpful).
The good news is none of my friends have the problem, only two of my computers and one tester in our organization (and have to get more details from her). Which is just to say whatever's happening is limited, so I'm less concerned (though no less confused...).
Thanks all for suggestions so far!
g.
